Are you tired of being distracted during online classes? Maybe you’re struggling to hear your teacher’s instructions over the sound of your neighbour’s lawn mower or your roommate’s music. Or maybe your peers can’t hear you because the sound of the fan is louder than your voice.
Well, why not try environmental noise cancellation (ENC) earbuds? ENC Earbuds will help you stay focused and allow you to participate in group discussions sans the disturbances.
Here are some factors you should look out for when buying noise cancelling earbuds for studying so you get that grade you’ve been working for.
Study sessions can be long, so you want a pair of noise-cancelling earbuds for studying that are comfortable to wear. Look for ones with different ear tip sizes to ensure a good fit and are made with soft materials.
The main purpose of noise-cancelling earbuds for studying is to reduce external noise and improve the sound quality you’re listening to. So, look for a pair that offers good sound quality and is tuned to suit your needs.
Long study sessions require long battery life, so choose earbuds with good battery life. Most noise-cancelling earbuds come with a charging case that can charge the earbuds on the go, so stay on the lookout for that too.
Look for earbuds with high-quality speaker drivers with good bass and clear treble. Also, look for larger speaker drivers for well-tuned accurate and balanced sound. With no ideal size for speaker drivers, 13 mm is a good size.
Yes, Mivi’s ENC earbuds can help you study by reducing external noise and improving the audio quality of your study materials. Here are Mivi’s best noise-cancelling earbuds for studying:
HD Calling with AI ENC for crystal-clear conversations.
Extended 50-hour playtime for uninterrupted listening.
13mm Electroplated Drivers for enhanced sound.
AAC Bluetooth Codec Support for superior audio transmission.
Ultra-responsive with 50ms low latency, perfect for gaming.
Swift 50ms latency elevates gaming experiences.
Generous 50-hour playtime.
13mm Electroplated Drivers guaranteeing rich sound.
Sleek, premium design that stands out.
Advanced connectivity with the latest 5.3 Bluetooth Version.
DuoPods K7 DuoPods features artificial intelligence to map your environment and create adaptive noise cancellation. So the receiver hears only you, not your background.
But that’s not all the earbuds have to offer; here are some important features:
Design: Its ergonomic and sleek metallic design gives it a starry night effect that will make you stand out from the crowd.
Sound Quality: It is powered by the Octa Bass tech for powerful, rich and deep bass.
Battery Life: It boasts a battery life of 50 hours (combined playtime); plus, it comes with a type-c fast charging feature that gives you 500 minutes of playtime with just 10 minutes of charge.
Speaker Drivers: It also has electroplated 13mm drivers with custom amplifiers that deliver a full range of sound.
DuoPods K1 features touch control technology to help you manage your calls, music and voice assistant with a simple tap on the pods.
With the following features K1 packs a subtle, but elegant punch like no other earbuds:
Design: The pair has a compact and ergonomic design and has a metallic finish on the pods. The case comes in four cutesy colors.
Sound Quality: K1 is powered by the electroplated technology that provides deep, thunderous bass and crisp sound.
Battery Life: This pair has a long-lasting battery life of 42 hours of combined playtime. Better yet, you can play it for 10 hours with just 15 minutes of charge.
Speaker drivers: The pair comes with 10.5 mm electroplated drivers and low latency.
So, if you want to take your online learning experience to the next level, why not try Mivi’s noise cancelling earbuds for studying? They’re the perfect combination of comfort and technology, designed in India to help you stay focused and productive.
