When it comes to earphones for sports, we all want something durable, sweat-resistant, and, most importantly, comfortable and secure. That’s basic.
Which specs set the best sports Bluetooth earphones apart from the rest? What should you look for when buying wireless earphones for your workouts?
Don’t worry; we’ve got you covered. Discover the technology and specs you need to know about to find your perfect pair of sports Bluetooth earphones.
The speaker drivers of sports wireless earbuds should be designed to provide high-quality audio focusing on clarity, balance, and power. They should be able to deliver crisp and clear audio across a wide frequency range, including the bass, midrange, and treble frequencies.
Consider the following features in the speaker drivers of sport earbuds:
Size: Look for larger drivers—13 mm—as they produce more bass and provide a more immersive experience.
Material: High-quality materials like neodymium can produce more powerful sound, while cheaper materials can produce lower-quality audio.
Impedance: Lower impedance can provide more power and volume, while higher impedance can provide better audio quality but at a lower volume.
Frequency response: A wide frequency response means the earphones can produce a full range of audio frequencies, resulting in better sound quality.
The audio codec used in sports earbuds should be designed to provide high-quality, low-latency audio with efficient use of battery life. A codec is a digital signal processing technology that compresses and decompresses audio signals for transmission and playback.
Consider the following factors when choosing the audio codec for sports neckbands:
Low Latency: The audio codec used in sports earbuds should have low latency, which is the delay between when the audio signal is sent and when the user hears it. Low latency ensures the audio is in sync with the user’s movements.
High Quality: The audio codec ensures no loss in audio quality during transmission and playback.
Compatibility: The audio codec should be compatible with various devices, including smartphones, tablets, and laptops, to ensure seamless playback across different devices.
Noise cancellation can help block out ambient noise, allowing you to focus on your music and workout.
Here are some technologies used in noise cancellation in sports Bluetooth earphones:
Environmental Noise Cancellation (ENC): ENC helps block out environmental noises that may interfere with your calls or music, such as the noise of fans, typing, or traffic.
Passive Noise Isolation: Earphones with this technology fit snugly in your ear canal and create a physical barrier that reduces the amount of external noise that enters your ear.
Ambient Sound Mode: Some earphones for sports offer an ambient sound mode that allows you to hear external noise like traffic, so you can remain aware of your surroundings while listening to your music.
Earphones for sports should have a secure fit to prevent water and dust from entering the earphones. They should be designed to withstand the wear and tear of outdoor activities.
An IPX rating (a rating that measures how well a device can resist dust and water) of IPX4 or higher is recommended for earphones to protect them from sweat and rain.
Regular cleaning of sports earbuds can help prevent the build-up of sweat, dirt, and dust, which can damage the earphones over time. So, look for earphones that have replaceable ear tips and filters.
Go for the latest Bluetooth version — 5.0 or above — these versions offer a longer range than the previous versions. The perfect Bluetooth range also depends on how you plan to use the earphones.
If you plan to use your sports earbuds indoors, a range of up to 30 feet (10 meters) should be sufficient. However, if you plan to use them outdoors, you may need a longer range, as obstacles like walls and trees can reduce the range.
If you wear smartwatches and other devices while playing or working out, you may need a longer range to maintain a stable connection.
Choosing a pair of earphones for sports with the highest battery life is not enough. Consider the following factors as well:
The time you can use them in a single charge should be at least 6 hours, as this should be enough for most workouts.
Look for earphones with a quick charging time, allowing you to recharge them quickly between workouts.
Look for earphones with lithium-ion batteries, as these tend to offer longer battery life than other types of batteries.
Look for sports earbuds with battery-saving features, such as auto-shutoff or low-power mode, to extend the battery life.
For buying the best pair of earphones for sports, look no further than Mivi. Immerse yourself in entertainment while working out with Mivi’s premium earbuds. Why wait to submerge yourself in awesomeness? Buy Mivi’s earbuds today and enrich your audio journey!
